wheel spacer installation!!
Old Jan 18, 2013 | 09:30 AM
tkkim's Avatar
Default wheel spacer installation!!
I bought spidertrax wheel spacer.
so I read
Spidertrax Wheel Spacers Installation Write-Up
this.
anyway, in here, he said i have to remove washer that came from stock.
so after installed wheel spacer, do i have to re-install that washer? or just put wheel on it?
Old Jan 18, 2013 | 09:34 AM
Slupe's Avatar
They can be sh@tcanned. Put wheel back on.
Old Jan 18, 2013 | 09:35 AM
whiskey_golf's Avatar
They don’t need to be reinstalled. I was gentle with the first set but then when I realized they weren’t going back on I just gorilla’d the others off and tossed them.
bob-o's Avatar
Ya remove and toss them
Old Jan 18, 2013 | 09:56 AM
tkkim's Avatar
sorry to be safe.
so I do not need to reinstall that washer right?
also do i need to use other new washer? or just put back wheel?
sorry I'm not a native so sometime confusing..
Old Jan 18, 2013 | 10:39 AM
JK-Ford's Avatar
x101 - Trash the washer.
Old Jan 18, 2013 | 11:21 PM
02604fun's Avatar
Default Warning
so I read
this.
Make damm sure the studs do not extend past the spacer or your wheel will not tighten to the spacer properly.
A few of my stud stuck out just a hair past the spacer and I had a wheel almost fall off!!!!!!!!!!!
Old Jan 18, 2013 | 11:50 PM
BlackRockBurner's Avatar
No washers, zero, zilch, nada. If the washers are left on, the spacer and rotor are not flush. Then they work their way up the studs and cause the spacer to separate from the rotor.
