Wheel spacer thickness??
I am planning on adding wheel spacers to my 08 JK Rubicon Unlimited in the near future. What is the narrowest/thinnest thickness I can go without trimming the wheel studs? Also, what sizes are available? I plan to use either Spidertracs or TereFlex for safety. I only do mild off-roading.
Spidertrax only makes a 1.5 spacer for the JK. I will use those if you really think that the tires will not extend pass the flares. I measured it, and it sure looked like it would.
P.S. Who makes a quality 1.25 spacer?
if you run 1.25" spacers, you will NEED to grind your wheel studs down a bit. i personally would recommend 1.5" spacers.
