Wheel spacers
I'm running them now. The question that comes to my mind is with locktite "setting" in the threads would retorquing the nuts help or hurt? If you break the set lock tite by slightly tightening them, are you helping or hurting? I'm not real sure of that answer
If you "break" the locktite then take the spacers off, remove old locktite with a wire brush, then reinstall from step one on the instructions.
Originally Posted by Tripletsi
You're not supposed to retorque at the same ft lbs you installed the spacers with. Say you install at 90ft lbs, then when you retorque use 85ft lbs.
