Wheel spacers
Old Nov 13, 2012 | 03:03 PM
PaddyD22's Avatar
Default Wheel spacers
Are they really worth it or not? Now I know we all love the aggressive looks to our jeeps but mechanically is it sound?
Old Nov 13, 2012 | 04:00 PM
Ryan0260's Avatar
If it's a good quality spacer that is installed correctly and periodically checked, then yes it is safe. I have ran a set of spidertrax for 3 years with no issues
Old Nov 13, 2012 | 04:05 PM
mattgt5's Avatar
I'm running them now. The question that comes to my mind is with locktite "setting" in the threads would retorquing the nuts help or hurt? If you break the set lock tite by slightly tightening them, are you helping or hurting? I'm not real sure of that answer
Old Nov 13, 2012 | 04:09 PM
Tripletsi's Avatar
You're not supposed to retorque at the same ft lbs you installed the spacers with. Say you install at 90ft lbs, then when you retorque use 85ft lbs.
If you "break" the locktite then take the spacers off, remove old locktite with a wire brush, then reinstall from step one on the instructions.
Old Nov 13, 2012 | 04:10 PM
mattgt5's Avatar
Ok, that makes sense. I have never heard that before.
