Wheel Spacers
Old May 14, 2013 | 09:33 AM
twinz33's Avatar
Default Wheel Spacers
I have 17x9in wheels with 4.75 backspace. Looking to purchase 1.5in spacers to help 37s fit better. Any reason not to run spacers with aftermarket wheels?
Searched as much as possible and cant find any clear reasoning on this
Old May 14, 2013 | 10:00 AM
SiliconTi's Avatar
Maybe...
Wheel spacers are hub centric, and the odds are that the aftermarket wheels are not. This will put too much stress on the spacer.
I'd *not* do it. Just get wheels with the correct backspacing.
Old May 14, 2013 | 10:09 AM
Rob 12B1P's Avatar
Not sure but wouldnt the resultant 3 1/4" backspacing be pretty hard on the unit bearings? Maybe a smaller size spacer would be better? Hopefully someone with experience will chime in.
Old May 15, 2013 | 06:51 AM
twinz33's Avatar
Anyone else with more info? So far im leaning on not taking the chance but im 50/50
Old May 15, 2013 | 07:07 AM
JKred's Avatar
Originally Posted by SiliconTi
Maybe...
Hub centric, non hub centric. Won't make a difference. The non hub centric wheel will just clamp and align solely on the lugs, just like it would on a normal hub. The "stress" will be the same as the same wheel on the hub/unit bearing.
As long as the spacer is properly torqued it isn't an issue in the least bit.
Yup, they'll be sticking out there, and yes it "more stress" on the unit bearing, but they can handle it. I've been running that little BS for almost 2 years, hard. There are a few guys running 5x5 to 5x5.5 adapters betting around 2" BS with no issues. Gives you a hell of a scrub radius too, making tuning easier lol
Old May 15, 2013 | 07:16 AM
Ryan0260's Avatar
37's should fit fine with the backspacing you currently have.
Old May 15, 2013 | 07:26 AM
JKred's Avatar
If the steering is limited, sure.
Old Jun 10, 2013 | 05:21 AM
twinz33's Avatar
Went with 1.5in spacers from Poison Spyder. Trimmed the pinch seem some and everything works fine on 3in of lift
ID:	466489   Click image for larger version
ID:	466490   Click image for larger version
ID:	466501   Click image for larger version
