wheel spacers
Old Feb 19, 2008 | 05:21 AM
jeep07's Avatar
Default wheel spacers
do I need wheel spacers for 33" , 12.4" wide tires on my 07 Wrangler X with 2" Full Traction lift?
Old Feb 19, 2008 | 06:01 AM
HappyCurmudgeon's Avatar
Eternal ***erator
If you are using stock rims? Yup.
If you are using aftermarket rims, just get the rims with the corrected backspacing, and that eliminates the need for spacers.
Old Feb 19, 2008 | 06:13 AM
jeep07's Avatar
Do you think 4.5" of backspacing will work? Thanks
Old Feb 19, 2008 | 06:49 AM
Eternal ***erator
anything between 3.75" and 4.75" should be fine. With the 4.75 possibly causing some rubbing at full flex. (factory Wheels have 6.25" of backspacing, so 6.25" - 1.5" spacers = 4.75" backspacing)
Just keep in mind, the LESS the backspacing, the Further it pushes the tires away from the Jeep.
You can reference this info here: Wheels & Tires
Old Feb 19, 2008 | 07:43 AM
jeep07's Avatar
Got it, Thank You
