Wheels advice needed
Old Apr 3, 2009 | 09:20 PM
MD5's Avatar
MD5
Default Wheels advice needed
I'm sad to post such kind of question because wheels advice are already discussed zillion of times but well, I'm confused and I'm trying to avoid a wrong purchase.
I need your help in selecting the right Pro Comp 7028 wheels for my JK Rubicon
http://www.procomptires.com/truck-jeep-wheels/pxa-series-7028-wheels.aspx
I actually run the stock 17" wheels and tyre.
I'm interested to know if the 7028 as is (without spacer) allow enough clearance to avoid rubbing and/or problem when using a 2.5" lift and if it is within factory flare limit (no rubber outside, strictly forbidden here).
Which P/N do I need ?
Thanks for any help!
Last edited by Robar; Apr 4, 2009 at 06:16 AM. Reason: PLEASE DO NOT POST DIRECT NON SPONSOR LINKS
Old Apr 4, 2009 | 04:10 AM
JK-KJ's Avatar
17x8.5, 5 on 5 Bolt Pattern
Backspace = 4.75 in.
Max Load = 2200lbs
Finish = Flat Black
Hub Centric = No
Offset = 0mm
Part No. = PXA7028-78573
^^^^ that's the one ^^^^
8.5" wide may be a little bit too wide for the stock size tire width, but it should be fine until you're able to get some new tires that are a bit wider
Old Apr 4, 2009 | 04:34 AM
08UnlimitedSahara810's Avatar
Nice looking wheel.
Old Apr 4, 2009 | 11:39 AM
MD5's Avatar
MD5
Thanks for the advice, I planned to use the above wheels with the stock GoodYear SilentArmor 255/75R17 tyres mainly for street/highway usage and very light offroad.
I own a second tyre/wheels set for offroad use:
What are the possible problem running stock tyre with this 8.5" wide wheel ?
