When to reprogram?
Old Mar 18, 2014 | 08:34 AM
Tango Alpha's Avatar
Default When to reprogram?
Replaced wheels and tires a few months back, and the Chrysler service guy recommended I reprogram for the larger diameter and extra wheel weight.*
I went from stock 255 75 17 SRAs to 285 70 17 Duratracs and Tracker wheels.
Do I really need to reprogram? What's the best way to do that? I'm certainly not paying the dealership to do it, they try to rip me of every time I go in there.
I did notice my mpgs took a hit of about 4mpg. From 20 to 16 mpg. I figured that was normal and to be expected. Could I get some of that back by reprogramming?
Old Mar 18, 2014 | 08:39 AM
crusaderJK's Avatar
Huh!? 255 75 17 and 270 70 17 are almost the same diameter....nothing noticeable.
Old Mar 18, 2014 | 08:41 AM
tribulation138's Avatar
I went from stock 255 75 17 SRAs to 275 70 17 Duratracs and Tracker wheels.
Its harder to calculate mpgs if you havent programmed the computer for larger tires. Cause the spedo will be off
Old Mar 18, 2014 | 09:16 AM
jadmt's Avatar
JK-Forum Ambassador
x2 maybe he meant 285/70-17 which is enough to make a small difference.
Old Mar 18, 2014 | 09:25 AM
crusaderJK's Avatar
yeah, maybe
And maybe I meant 275 70 17.. LOL
Just a typo...my calculation was right though.
Old Mar 18, 2014 | 09:35 AM
reddoak's Avatar
I went from the stock steel 16s to a set of "S" alloys and 17s, and the speedo was off by a noticeable amount. The dealer could reprogram it, but I got a Flashcal and did it myself. Plus, no more reprogramming if I change sizes.
Old Mar 18, 2014 | 09:41 AM
crusaderJK's Avatar
Why would someone have to reprogram for heavier/lighter tires?? I know it affects the ride quality and mpg but I don't see where it should affect the speedo.
Old Mar 18, 2014 | 09:46 AM
XTJake's Avatar
Former Vendor
If you do decide to reprogram you can use the Superchips Flashcal. This is allow you to adjust for the tire size and a few other things. Let me know if you have any specific questions or if you'd like a quote!
-Ryan
Old Mar 18, 2014 | 09:47 AM
kh202's Avatar
You don't . Only if diameter changes
Old Mar 18, 2014 | 09:51 AM
crusaderJK's Avatar
Right, thanks!! Thought I was missing something.
