Where did you mount your ARB Twin?
#41
Can you mount ARB twin under the rear seat in 2016 2 door?
Hi guys I'm new here. I just bought the twin arb and want to keep it away from engine heat and water.
Can the twin be mounted under the rear jk seat in the 2016 2 door model?
Also, would I need to extend the wiring that comes with the compressor for the lockers and battery source?
Thanks for all the help and suggestions.
John
John
#42
John
John
#43
Thanks for the speedy reply too. 👍
#44
Wow nice setup.
I found online a company WD that makes a bracket for the 2 door arb that mount on the left rear side however the rear seat has to be removed.
I could live without the rear seat I guess.
#49
Watching this thread..
I've got the itch to install an ARB twin in my 2013 JKU. So far, I like the last photo the best, but doesn't that go into the left rear wheelwell?! Also, I'd worry about the lack of adequate airflow for cooling during full-duty use.
I tend to get creative, so let's see what I can come up with. I'm going to want at least a 2-gallon air tank as well. I saw a photo of a guy who mounted one above the rear axle...
With a pair of Odessey 34 batteries under the hood on a Genesis tray, there's not much room for more. Plus I'm driving a RHD JKU, so things can get a bit tricky with installations. Will the mount for putting it under the passenger seat work on MY passenger seat (which is on the left)? I have a Tuffy lock-box under my driver's seat (right side).
I'll probably go with under the rear seat. Lots of good ideas! Thanks for the help guys.
Tom
Tom
#50
Tom, what do you plan on using the compressor for? Even with a 2-gallon tank, I don't think you're going to be thrilled with using it for pneumatic tools if that is the thought. I have that compressor and have been very happy with it for about 5 years now; however, it is primarily just used for airing up tires.
