Where do you mount your fire extinguisher?
Old 02-04-2016, 08:41 AM
  #21
Flywrangler's Avatar
Google drake extinguisher mount. I'm going to mount a couple on the trail cage C-pillars.
Old 02-04-2016, 09:14 AM
  #22
John_fender's Avatar
I'm using the weld on quick release mounts from Stinky Fab. I have one 5lb halon and one 5lb dry cheIf you have Click image for larger version
ID:	636615ever seen a car burn, then you know that a 2lb extinguisher is too small.
Old 02-04-2016, 05:58 PM
  #23
'11BronzeStar70th's Avatar
To extinguish a fire, HALON merely disrupts the combustion process (fuel + heat + oxygen = combustion process, i.e. FIRE!). HALON needs to maintain a level of concentration until one of those items is removed/is no longer present. A contained fire inside the closed passenger compartment of a vehicle can be extinguished with HALON, providing that concentration is maintained. A fire in an engine compartment or an open Jeep cabin would need a LOT of HALON applied repeatedly. Dry Chem, although messy and corrosive unless removed promptly, remains a very effective means of extinguishing a petroleum fed fire.
Old 02-04-2016, 08:19 PM
  #24
orangedude71's Avatar
I keep an ab mounted to the drivers side seat rail and an abc mounted to the passenger side seat rail.
Old 02-05-2016, 07:54 AM
  #25
LoneWolf's Avatar
Back of the sport cage, driver's side. It's out of the way for daily use, but easy to reach if I ever need it.
Old 06-14-2016, 06:45 AM
  #26
Toxic Tiki's Avatar
Driver's seat between door and seat. Used the mount that came with the extinguisher. Used 1 of the existing holes in the seat post and drilled the second. Out of sight, secure and easy to reach.
Quick Reply: Where do you mount your fire extinguisher?
