who makes front tracbar drop bracket
who makes a front trac bar drop bracket (frame ) and pitman arm so i can bring my drag link and trac bar as clode to paralell as possible..... i cannot use the teraflex draglink flip kit since i no longer have the stock drag link and their unit uses the factory adjuster sleeve.....i need this since i do have 4" of lift or slightly more......thanx guys , any help is greatly appreciated !
I am using a Full Traction frame mounted drop bracket and what ever kind of drop pitman arm David, Northridge4x4, sent me. The drop bracket is a stout piece of metal.
Sorry, the bracket is a little blurry, but you can see my tire tread quite clearly.
Thanx for the help, I guess I'll give dave a call @ northridge and I'll just have to choose between The two. The brace your refering to, is it a sector shaft brace?
I'm looking to beef up the entire front end Wd much as possible, you know the d30 gussets n stuff as well as steering components.... Thanx for the input guys
