Why is it....
Old Mar 4, 2013 | 10:00 AM
sburggsx's Avatar
Default Why is it....
That you can't use a RFE545 or the new 3.6 tranny with a 3.8?
I mean what exactly are the technial reasons? Have we finally gotten to the point where you can't swap parts around?
Old Mar 4, 2013 | 01:04 PM
jk_sea's Avatar
Isn't the auto paired with the 3.6 the Chrysler NAG1? (I forget what the Mercedes model # is but they're the same unit).
I'd imagine the bellhousing and input shafts are completely different, for starters.
Old Mar 4, 2013 | 01:46 PM
JKbender's Avatar
If this is something you are trying to make work then I would sugest that you give Advanced Adapters a call. Worst case they can give you a straight answer quickly, best case they will have a solution for you already figured out.
Old Mar 5, 2013 | 01:20 PM
sburggsx's Avatar
Everything I've heard before this is the computer end is the non-starter. You don't even get to bellhousing/shaft issues.
