Why Do I keep busting gears?
Old Apr 25, 2012 | 06:16 PM
Dblaron's Avatar
Agree totally with climbbig. Your pinion depth is off. you need to make sure your wear marks are towards the center and oval shaped not moon or to inside edge or outside edge. The pinion crush sleeve took a break bar and huge piece of angle iron using the stock flange bolts and all my leg strength to get 1/4 turns. The pinion needs to be at 10-16 inch lbs of force. And that is measured while your spinning not just force required to start spin. I have a dana 30 front i wheel mostly 3-5 rated trails and no problems. Just leave it unlocked and dont power thru things.
Old Apr 25, 2012 | 10:15 PM
carolinajk's Avatar
those wear marks on opposite ends of the teeth are associated with incorrect pinion depth for sure
Old Apr 25, 2012 | 10:22 PM
Vann's Avatar
Originally Posted by TeraFlex
Got a diesel in your JK? Just curious if you do. I have some customers with diesels that can not keep gears in them.
No, just the 3.8 with some minor mods, chip ect, nothing even close to what the 2.8crd's push out.
Originally Posted by carolinajk
they check and replace the bearings with the second install?0
AFAIK, yes, I gave them a full overhaull kit, every time the re-gear was done.
Originally Posted by 2climbbig
Couple of things are wrong here. First, the pinion depth is wrong just looking at the wear pattern. Second, the last time i saw an inconsistent pattern, the pinion nut was not torqued down correctly. I recently rebuilt my front pinion and the crush sleeve was an absolute pain to crush. I had to use a 6 foot 3/4 inch breaker bar. Also, strength wise, a 5.13 pinion on a dana 30 is not a strong combo. This wont be your last rebuild on that axle.
Thanks for the reply man, yea the D30 is only for a couple of month's, Then I'll upgrade to a D44 front, and a D60 rear, but at this stage, they are using my savings to fix their issues... !
Originally Posted by Dblaron
Agree totally with climbbig. Your pinion depth is off. you need to make sure your wear marks are towards the center and oval shaped not moon or to inside edge or outside edge. The pinion crush sleeve took a break bar and huge piece of angle iron using the stock flange bolts and all my leg strength to get 1/4 turns. The pinion needs to be at 10-16 inch lbs of force. And that is measured while your spinning not just force required to start spin. I have a dana 30 front i wheel mostly 3-5 rated trails and no problems. Just leave it unlocked and don't power thru things.
Thanks a lot, noted!!
Thanks again for every one replying, it is helping me out a lot!.
