Why flex arms?
Old Dec 7, 2011 | 08:41 PM
Crazecodyk's Avatar
Default Why flex arms?
i just read through the instructions i recieved with my full traction flex arm kit...they say to adjust them to factory arm length...why am i doing this? i don't have to make them longer due to the 4 inches i'm adding to the suspension? if they are the same length as stock why the point of upgrading? just curious.
Old Dec 7, 2011 | 10:34 PM
POTO's Avatar
The "flex" is only referring to the joints on the arms and give your suspension more articulation. You set length to stock so you can install them easier, once installed you adjust to correct your pinion angles. HTH
Old Dec 8, 2011 | 07:29 AM
Full-Traction Suspension's Avatar
Former Member
The stock length is just a starting point. Here's a detailed write up on your same kit.
However, this is the old style joints, so please ignore the grease, zerks etc. The control arm lengths and install will be the same.
http://project-jk.com/jeep-jk-write-...ation-write-up
Old Dec 8, 2011 | 12:13 PM
Crazecodyk's Avatar
The 4" comes with extension brackets. But most part it is the same kit as the 3 just different springs. I will be using that as a guide to my install...still greek about setting pinion and castor angles right now but im sure i'll get it..just not seeing it in my head good enough
Old Dec 8, 2011 | 12:50 PM
Former Member
springs, trackbar brackets, pitman arm..
Give me a ring when your setting your pinion and caster angles. I'll explain it.
Its very simple
Old Dec 9, 2011 | 08:45 AM
Crazecodyk's Avatar
I got you on speed dial lol. The new drive shaft is throwing a kink in it but it's gotta be done..i guess once i start doing it everything will fall into place. Just scared once i get it broke down and get in a bind im flintstonin it till i get through it lol
Old Dec 9, 2011 | 09:03 AM
JKred's Avatar
Honestly I just did everything your doing so if you need any advice or little tricks I found to work let me know.
