Why now after 3 years
Driving today around 50 mph hit bump with right tire and the front end started to shake. Thus happen twice today
I have a 2.5 TF Lift which has been on there for over a year and tires are 285/70/17 and all 5 are rotated every 3000 miles. Dies anybody haves any ideas or suggestions.
Most likely it is something came loose. I don't think it is much to do with the TF lift, check your track bars, most likely the cause of the wobble. Check if the eyes (where the bolt goes through) isn't oval, oval means that it has been loose for a wee while. Tighten everything I would say.
Cheers,
Mark
Cheers,
Mark
You have experienced death wobble. It is not uncommon and it has happened to alot of JKers. Read this thread carefully and then act accordingly.
https://www.jk-forum.com/forums/show...hlight=planman
Good luck and please keep us updated.
X2 on ball joints, tire balance and bent tie rod bar. That is the combo that started my DW after many years of smooth driving with my lift. Replacing the ball joints, and tire rod really did it for me.
Oh, and a leaking steering stabilizer didn't help either, but that's never the cause of DW.
