Why is regearing important?
Old Mar 8, 2014 | 04:07 AM
  #21
RockinRubiAnn's Avatar
Originally Posted by itsthelaw
Great info and advice. Mine were done by a guy who was a Jeep dealer service tech for 17 years. He now works on Jeeps as a passion/hobby/business. They cost me $1100 including the gears. They MUST be done by someone who can set the tolerances!
Good to know there is another guy from Asheville on here. Who did you use for regearing? I'm assuming he does lifts too. I'm thinking about trying to install an AEV 2.5" lift on my own but definitely not the regearing piece.
Old Mar 15, 2014 | 02:05 PM
  #22
ufgeek's Avatar
The AEV kit was a very easy to install. I didn't have a lot of experience wrenching before doing it. I would spring for a set of grade 8 bolts while you have everything apart. The whole thing took me about 8 hours... which included several trips to ACE to get a couple of new bolts, and a tool or two. There may have been a beer run in there
I ended up using a pair of floor jacks. One to hold up the axle at the diff and the other to help compress the 1st spring when putting in the second.
Old Mar 15, 2014 | 06:03 PM
  #23
Originally Posted by ufgeek
The AEV kit was a very easy to install. I didn't have a lot of experience wrenching before doing it. I would spring for a set of grade 8 bolts while you have everything apart. The whole thing took me about 8 hours... which included several trips to ACE to get a couple of new bolts, and a tool or two. There may have been a beer run in there I ended up using a pair of floor jacks. One to hold up the axle at the diff and the other to help compress the 1st spring when putting in the second.
Thanks for the info. Will get the bolts before I start but the beer run in the middle sounds like a good break.
