will a 2.5" fit 35's?
i want to lift my jk x 2 door and i dont want to change the way it drives or effect the mpg to terribly...i have in mind a budget boost 2.5" lift will that clear 35-12.50?...will that be alot, little,or no tire scrubbing
I'm also looking at the same type of setup. Keeping the stock tires for everyday, and the 35's for wheeling trips.
I have the 2.5 tf bb and run 35 cooper stt's on 15x8 pro comp rock crawlers w/3.75 backspacing with no rub anytime including wheeling.I was expecting to rub on the front bumper stuffed and turned but just squeeks by.here are some pic's.Could'nt be happier.Click for slide show.http://s105.photobucket.com/albums/m...t=6d394153.pbw
Only rubbed when full flex, and no it wasn't enough to tear off the fenders, just an annoying/loud sound as the tire's tread rubbed across the fender lip. Freaks you out the first time you hear it because it sounds like you're tearing the fender completely off. But once you hear it a few times you get used to it.
