Will 4.56 run in a D30 and D44?
Old Mar 28, 2009 | 09:37 PM
RN M OVR's Avatar
Default Will 4.56 run in a D30 and D44?
I want to install 4.56 gearing b/c I'm running close to 35's. Regardless, I have a couple questions....
1.) Will 4.56 fit and run alright in a front D30 and a rear D44?
2.) Should I get Superior?
Thanks!
Old Mar 28, 2009 | 09:44 PM
wayoflife's Avatar
JK-Forum Founder
Yes, they will work and yes, i think you will be happy with the ones superior makes.
Old Mar 28, 2009 | 09:46 PM
RN M OVR's Avatar
HAHAHA! I just got your message WOL.
Thank you for the help. Superior it is.
With 4.56 and running close to 35's, what should expect? -- more torque and less MPG, or roughly factory MPG, bad torque but good MPG?
Old Mar 28, 2009 | 09:52 PM
wayoflife's Avatar
JK-Forum Founder
honestly, i personally would recommend getting 4.88's if you're going to be running a 35" tire or close to it. that will give you close to factory performance. also, other makes you can check out are randy's ring and pinion, yukon and genuine.
Old Mar 28, 2009 | 09:54 PM
bigbluejk's Avatar
I have 5.13s spinning my 35s. The original plan was chopped fenders and 37s, but I love the extra power. They should come this way.
Old Mar 28, 2009 | 09:57 PM
wayoflife's Avatar
JK-Forum Founder
honestly, that really was my favorite setup. 5.13's and 35's and a 6-speed was oh so much fun!!
Old Mar 28, 2009 | 10:03 PM
RN M OVR's Avatar
Thanks alot. Much appreciated!
Old Mar 28, 2009 | 10:51 PM
Mk-Dubai's Avatar
i have 4.56 superiors installed on D30 and D44 on my rig and there are no issues whatsoever.
you will NOT regert it.
Old Mar 29, 2009 | 12:15 AM
SLeepY_BoY's Avatar
i have 4.56 and d30 and d44 and couldnt be happier
Old Mar 29, 2009 | 09:47 AM
Torrin's Avatar
Thanks!
You will need a new carrier for the 30, but beyond that, your golden. IMHO 4.56 is probably a little big for 35's, you might want to think about 4.88's or even 5.13's.
