Will it work?
Old May 25, 2018 | 05:38 PM
Randy_Q's Avatar
Veteran: Marine Corp
Default Will it work?
I've seen quite a few mall crawler jeeps running around on 35's with only a 2.5 in lift and can tell that if they went off road they'd rub. So what I want to know since this is my first wrangler is would flat fenders keep it from rubbing and how much says would it have once I add on belly armor, rock sliders, front and rear bumpers and get a spare tire carrier that can hold the larger tire. And would it be better to get 3.5 in lift or go with a 2.5 and get a 1/2-1 in body lift. I would like to be able to do the Rubicon trail without bypassing very much and not damaging the body much as this is what I use to get to work which is 120 miles but only done once a month.
Old May 26, 2018 | 03:43 AM
karls10jk's Avatar
35's with 2.5" doesn't have to rub if they've got it properly bumpstopped. I've got that setup with trimmed factory flares and it doesn't rub.
Armor is good but it adds weight, weight brings you closer to the rocks you want to avoid. Add only what's necessary.
Old May 26, 2018 | 04:00 PM
Randy_Q's Avatar
Ya I want the armor so I can do some of the black trails and like I said I'd like to do the Rubicon trail without having to bypass much if anything and tear up my jeep. What size bump stop extensions do you have? And do you know the actual size of your tires? Because I've been looking around and most 35's are between 33-34 inches in actual height. And the ones I'm wanting are 34.6" tall with the vehicle sitting on the ground.
Last edited by Randy_Q; May 26, 2018 at 04:02 PM. Reason: Forgot to add tires I'll be running
Old May 27, 2018 | 06:14 AM
karls10jk's Avatar
I'm not running any extra bumpstop than what the jeep came with but I've also modified my shock mounts and chosen the correct length shocks to avoid bottoming them out or putting a tire into any plastic. All tire manufacturers lie and you'll see that the difference in the weight of the vehicle is going to change the height of the tire as well. My 315/70-17 bfg's are advertised as 34 and change but they measure 33.75" for my tuner. Take into consideration that I'm also running an 8.5" wheel vs most aftermarkets will be 9 and the factory is 7.5". Let's go even further with it- you'll drop your tire pressure, let's estimate down to 15psi....how much ground clearance will you have now with the armor?
I've added bumpers (stubby front, aluminum rear), diy side rails, a super thick oil pan (benchmark designs), and an evap canister skid. I've maybe touched the skid once or twice. Your money is safe there to prevent a CEL but you should invest in lower control arm skids, preferably ones that weld on. The lower shock mounts in the rear will grab plenty of rocks if the Rubicon is anything like East Coast wheeling.
Old May 27, 2018 | 03:01 PM
jsukey's Avatar
I've been running the Rock Krawler 2.5 X-Factor for over 4 years on my Jeep with Nitto Trail Grappler 35's and 2" bumpstops. I've got front and rear AEV bumpers with a 10k Warn Zeon 10S, JCR rock sliders, added RockHard 4X4's engine/tranny and transfer case skids a few months ago. I was still running the factory flares with it and never had any rubbing issues. I just jumped up to 37" trail Grapplers and Spyderlock beadlocks. I trimmed my factory flares, removed the rear inner wheel liners, and trimmed the front AEV bumper. No rubbing on the RTI ramp, but we'll see how it does once I get a chance to get it in the rocks. Still running the same 2" bumpstops.
