Winch??
the m8000 is ok if you have a 2 door. for an unlimited, i wouldn't go any lower than 9500lbs
That m8000 is still pushing it on a rubicon 2-door too. curb weight is over 4100lbs. You want between 2-3X the pull strength. Don't forget, the more line you have out, the less the winch can pull. Granted you can use snatch blocks, that's just one more thing to set up properly.
Superwinch EPi or EP 9000. Comes with a snatch block and you can find them for a pretty decent price, usually around $600. There also perfect for synthetic line becuase the break isn't inside the drum. No worrys about melting your line... designed in USA made in Taiwan & china
