Winch connection to battery
I recently received and installed a smittybilt xrc10 winch. I thought I had done everything right, but as usual after reding this forum I ran across some comments that you shouldn't connect the winch to the smaller side like posts that are on the factory battery. So my question is, is this true ? If so, then why do winches come with cables that only fit on the smaller posts ? It would seem if that is how they are made and these companies have been in the business for a long time then it would be perfectly fine to use the side posts.
I don't still have the stock battery, but I also don't remember the stock battery having side posts.
I found a picture of my stock battery. Are you talking about the post thats on top? If so, you'll be fine. Think about how many amps your starter draws.
A winch is about the largest current drain you could ever hook up to your battery. When the winch is under heavy load (especially if it's stalled), it can draw in excess of 500A. Far more than your starter ever will.
BTW: Here are the current specs for a Warn XD900i
http://www.gowarn.com/xd9000i-winch.asp
Chris.
To be honest, when it comes to vehicles I am at the lower end of knowing all of the correct terminology. My jeep JK is the first vehicle that I have actually taken an interest in learning about as well as performing maintenance and installing upgrades. So as far as me saying "side posts", whatever the stock battery has is what I'm speaking of. The winch cables don't actually connect to the large posts on top but rather the smaller ones that come off from those.
FYI - running a winch off a factory battery is not recommended. Go get yourself a nice deep cycle battery like a Yellow Top Optima. One hard pull on that factory battery and it's toast! Always connect to the top post, not side posts. Side posts are not designed to handle the draw of a winch.
However, this is only a problem if you are winching with the engine off (in deep water or mud for example). Shouldn't be a problem if you keep the engine running.
