Winch with Factory Bumper???
Old Mar 29, 2009 | 04:51 PM
hayden911's Avatar
Question Winch with Factory Bumper???
I have an 08 JK and want a winch, unfortunately I'm on a low budget. Is there any winch available that you can simply use a plate with and mount to the factory bumper? This may be a stupid question but I am new at the mods on jeeps. Any advice is welcomed
Old Mar 30, 2009 | 01:35 PM
Cdash's Avatar
There are several winch plates out there. Not sure if any are true bolt on, but you would remove the plastic cover between the factory bumper and the grill for mounting. It can be done, you may have to do some cutting and grinding of the winch plate for fit issues.
I am looking to do this eventually, but $$ isn't growing on trees in Michigan..... I can't even make it to low budget yet.
Old Mar 30, 2009 | 07:09 PM
jeeper93436's Avatar
rough country has one. it looks like it bolts up were the front tow hooks bolt to. it kinda pricey i think. its just a 1/4 plate with bolt holes to bolt it down and for the winch.
Old Mar 30, 2009 | 07:50 PM
capt scotty's Avatar
I ended up using a Champion winch from Coscso. 8000# came with the plate, roller fairlead and snatchblock. It was $299.00. I had to cut the bumper to fit around the plate. It is solidly mounted to the frame. It works for me.
