Winch lines
Old Nov 20, 2007 | 11:45 AM
blackmarketg4's Avatar
Default Winch lines
After using your winch, is there any way to get the cable wound back up, close to how it came from the factory?
Old Nov 20, 2007 | 12:23 PM
1BADJK's Avatar
Easy.. Wind it back up under a light load.. The rolling weight of the vehicle works great..
Old Nov 20, 2007 | 12:45 PM
shrockworks's Avatar
Former Vendor
or get synth rope....my wire ropes always ended up a mess.
Old Nov 20, 2007 | 01:09 PM
gldwings1's Avatar
I agree with synthetic winch rope.
Old Nov 20, 2007 | 02:18 PM
2K1TJ's Avatar
x3.
Old Nov 20, 2007 | 03:52 PM
0verride's Avatar
Not to mention synthetic makes for less time durring recoveries. Its just easier to pull out, and get set up.
Old Nov 20, 2007 | 06:26 PM
crux's Avatar
Originally Posted by putnam dan
That is true - but the saftey side is in my view a myth. Yes you can get wire splinters (not from synthetic) but this is an indicator that your cable should be replaced, yes the synthetic can fray too (less noticable) and both can be cut, but getting cut in half by a snapping cable NO, find an example if you can.
Major injuries can occur if a cable brakes, but generally from the falling load. Both synthetic and wire are a risk here if not well maintained.
Synthetic is nicer and easier to handle - major advantages - but I'm not sure its any safer.
I kinda agree with you there. Most people, including myself tend to forget about winch line until you need it. I would put my trust in a steel cable before synth just for the fact that anything not covered & left out in the elements will tend to deteriorate from sun rays,water, grit etc. Steel cable corrodes, but wont snap from it`s fibers rotting. There have always been the thing about cable snapping and taking someone or something out.I`m sure thats happened, but chances are slim. I`d be more concerned with line fatigue, and having your vehicle go tumbling down or rolling over or whatever.
Old Nov 20, 2007 | 06:30 PM
NDynamite's Avatar
That is true - but the saftey side is in my view a myth....
I think Mythbusters on the Discovery Channel did a segment on this a while back. If I recall correctly, their tests backed up your view. Anybody see that episode?
Old Nov 20, 2007 | 06:35 PM
tgrt's Avatar
Former Vendor
This is interesting: http://mythbustersresults.com/episode62.
Old Nov 21, 2007 | 04:22 AM
Former Vendor
Originally Posted by tgrt
That is interesting. Wish I saw that one. It did say that it "did cause potentially lethal injuries" though.
