Winch question
I just routed mine under the front grill above the sway bar and over to the battery. Heat shouldn't be an issue as long as its not extreme. Just make sure you route the wire away from anything that can cut or wear through the wires coating. and/or put it in a protective sheath.
I run the stock battery and it works fine. Like it was mentioned previously, just keep the engine running. As for the wires I ran mine under the grille and past the airbox to the battery. I also covered mine in some standard automobile wiring insulator that I picked up from autozone. Good luck!
