Winch question
Old Jun 22, 2013 | 04:17 AM
LSM's Avatar
LSM
Default Winch question
Not sure if this is the right place for this but what is the best way to run the winch cables to the battery? Does it matter if they get hot?
Old Jun 22, 2013 | 04:47 AM
roscoj's Avatar
I just routed mine under the front grill above the sway bar and over to the battery. Heat shouldn't be an issue as long as its not extreme. Just make sure you route the wire away from anything that can cut or wear through the wires coating. and/or put it in a protective sheath.
Old Jun 22, 2013 | 05:25 AM
Jersey_Devil's Avatar
Yup! Just like this and Ul be just fine!
Old Jul 21, 2013 | 10:37 PM
nik81818's Avatar
What battery do u guys run with a winch? Stock one fine? I was thinking of upgrading to an optima yellow top
Old Jul 22, 2013 | 02:58 AM
Bushmaster's Avatar
I run an optima yellow top. I cooked the stock one winching. It dropped a cell but was almost 2 years old.
Old Jul 22, 2013 | 07:10 PM
Ryan0260's Avatar
An Optima yellow top is a good choice for winching.
Old Jul 22, 2013 | 07:17 PM
karls's Avatar
I'm rocking a red top but then again- I don't winch every weekend. I just do the monthly maintenance.
Sent from my Droid4 and Jkfreaks.com
Old Jul 22, 2013 | 08:47 PM
Red Dog's Avatar
Yellow top here too. Always run the engine when winching.
Old Jul 22, 2013 | 09:18 PM
Trail Duty's Avatar
I run the stock battery and it works fine. Like it was mentioned previously, just keep the engine running. As for the wires I ran mine under the grille and past the airbox to the battery. I also covered mine in some standard automobile wiring insulator that I picked up from autozone. Good luck!
Old Jul 23, 2013 | 05:08 AM
Ryan0260's Avatar
The stock battery won't last long if the winch sees much use..
