winch trouble
Old Oct 11, 2009 | 08:51 AM
LaxAHolic's Avatar
Default winch trouble
i tried to wire up my warn m8000 last night...red to red on the battery...black to black..it couldnt have been hard, or could it?
anyways, it didnt work...at all...is there something im doing completely wrong?
Old Oct 11, 2009 | 10:45 AM
Jusaplaya's Avatar
That is what I did red to red and black to black. I also wrapped the red wire in loom to make sure that it wouldn't rub and short out. Bad solenoid maybe?
Old Oct 11, 2009 | 11:38 AM
AK4Dave's Avatar
Man that's a drag for sure, can't imagine what it would be other than like jusaplaya said......bad solenoid..??? Did you smack it a few times? corroded contacts?
Speaking of solenoid (not to hijack the thread) but I picked up a brand new M8000 but it doesn't have the solenoid or the remote, Does anybody know where I can get one for a decent price? Warn wants an arm and a leg for the damn things....!!!
Old Oct 11, 2009 | 01:30 PM
LaxAHolic's Avatar
...is there an on switch? something simple...i may be missing?
Old Oct 11, 2009 | 02:02 PM
Jusaplaya's Avatar
Should be a remote control that comes with it that plugs in the side. Do you have that? Be sure to respool it for the first time when you get it working.
Old Oct 11, 2009 | 02:04 PM
Yoda's Avatar
Typical solenoid problem on the Warn's
I had a 9500 ti one year ago with the same problem
Old Oct 11, 2009 | 02:38 PM
NTXJK's Avatar
That sucks all that money for the Warn and nothing I hope you find the problem
Old Oct 11, 2009 | 06:14 PM
LaxAHolic's Avatar
yeah, i have the remote...
i have no idea whats goin on...
Old Oct 12, 2009 | 04:00 AM
gotrdone's Avatar
Default cruddy
was the winch new when you installed it?
if it was not, perhaps the contact points on yr remote are not
making a good connection. much like trailer wiring that gets
dirty. as with that stuff, one has to fuss around w/ it......
why should you re-spool it the first time jusaplaya??
does this apply if you have syn. line?
Old Oct 12, 2009 | 04:59 AM
Mark Doiron's Avatar
On my Warn PowerPlant, there's an on-off switch on the remote itself. It has the generic "you're-too-stupid-to-read" on and off symbols. EDIT: I made a mistake--this control is for the air compressor.
There's a separate control to tell the winch which direction to spool. The winch won't budge until you tell it which way (that switch must be held to keep it moving).
If that's not the problem contact Warn. A couple others have mentioned problems over the last couple years, but all have had immediate response from Warn to get it fixed.
Last edited by Mark Doiron; Oct 12, 2009 at 07:16 AM. Reason: Edited my mistaken post.
