Winch wiring
Winch wiring
I am needing some help with my winch to make sure that I routed the wires right, i mean the way I did it , it works but I jsut dont want to damage anything
I ran them from the control box into the grill and to the left in the little upper hole by the radiator, will the wires be ok there or do I need to relocate them , I dont konw much about anything, will they get hot or hte radiator get hot?
htanks
derek
htanks
derek
I didnt run mine through the grill because I figured it would rub the paint off the grill. I wrapped the power wires with black plastic wire cover to prevent UV damage. Ran the wires under the left side of the grill and weasel them into the engine bay. Like a glove!
pictures of that please
thanks for the replies
one other thing
do I need dto have some sort of fuse in between the battery and the winch, cause right now I just got it going start to this
reason I ask is because I remember a fuse being on the CB
one other thing
Any others running without fuse, this seems a bit dangerous but maybe I dont know enough about winches?
Couldnt that cause a burn down or something ...bad short
