Winches
Old Feb 11, 2013 | 04:42 PM
Ryan0260's Avatar
Depends on how much you plan to use it, and what the budget is. For occasional, a cheaper one will work fine. Also, a good deep cycle battery will give you the power you need. I went with an Optima yellow top,and it works great.
Old Feb 12, 2013 | 11:47 AM
finnsisu's Avatar
Thank you all for the good info! A little more research and I think I will have one pegged! More to follow when I find one.
Old Feb 12, 2013 | 11:58 AM
JK-Ford's Avatar
Just be a good energy conservationist when using your winch and you'll be fine. Allow the battery to recharge for a little while before shutting down the Jeep. Or diveing off into another pull.
Old Mar 1, 2013 | 10:53 AM
finnsisu's Avatar
Well, I went with a rugged ridge 8000 lb winch. Just put a RR bumper on and the winch will go in this week, pictures to follow!
Old Mar 1, 2013 | 12:32 PM
RDH475's Avatar
Originally Posted by taylorthedude
Massive Multi-Winch Shootout - Four Wheeler Magazine
check out this site, it may help you out
Did you see the research as to why the warn broke internal parts, it was determined that a 16,000lb pull mounted to a 9,500lb rated mount, the mount deflected stressing the case resulting in broken internals. Funny how they didnt give all the info the first time.
