Window problem
I have a new Drivers window problem.
This was done 2 weeks ago and i have been just putting a big trash bag over the door when parked and just going with an open window when driving.
I have been thinking about replacing it with an other glass window and Dealer wants $201.00 for the window and Moparpartsamerica wants $144.00.
I have been also playing with the idea of just getting some plexi from Home depot and making my own, the only problem is that i do NOT have the window measurements.
Any ideas would be great,
Kat
Kat
Used to know a guy who put a plexiglass window on his hatchback. After a while, it discolored to a yellow tone, and you have to be really careful when you clean it because it scratches, like paint does. Over time he just had a fuzzy yellow window. Looked horrible.
I don't know if it'd be any cheaper, but there's alot of aftermarket glass companies.. If you have a "speedy glass" or "windshield world" or something around, maybe you should check prices with them?
as for the dent, I've been sitting at the computer too long... I can't remember what the inside of the door looks like now.. If the panel is removed, can the dent maybe be pushed from the inside?
NORMALLY its a royal PITA to remove the door panel because the window is attached to the inner panel. But if its completely broken, should be very easy to remove and replace. If i had known it was that cheap i woulda just busted the darn windows out when i did my door lock actuators
nice new avatar
