Window problem
Old Apr 2, 2009 | 07:54 AM
jkkat's Avatar
Default Window problem
I have a new Drivers window problem.
This was done 2 weeks ago and i have been just putting a big trash bag over the door when parked and just going with an open window when driving.
I have been thinking about replacing it with an other glass window and Dealer wants $201.00 for the window and Moparpartsamerica wants $144.00.
I have been also playing with the idea of just getting some plexi from Home depot and making my own, the only problem is that i do NOT have the window measurements.
Any ideas would be great,
Kat
Old Apr 2, 2009 | 07:58 AM
RedneckJeep's Avatar
Soap up the door and a bathroom plunger and give that a try. It might pull enough of it out to let the window work. Be careful though. These doors are thin.
Old Apr 2, 2009 | 08:04 AM
csorensen's Avatar
Looking at that dent, I'd be shocked if the window wasn't shattered inside the door......
I suppose you would need the measurements of the window uninstalled right?
Old Apr 2, 2009 | 08:08 AM
jkkat's Avatar
The window did shatter on the inside because i slid sideways in mud while going up and slide into a tree root ball that fell over.
greenamphibious's Avatar
www dot safelite dot com
Old Apr 2, 2009 | 08:11 AM
robin's Avatar
I'm not sure about the plexiglass idea nice new avatar
Old Apr 2, 2009 | 09:22 AM
JK Rocker's Avatar
Used to know a guy who put a plexiglass window on his hatchback. After a while, it discolored to a yellow tone, and you have to be really careful when you clean it because it scratches, like paint does. Over time he just had a fuzzy yellow window. Looked horrible.
Old Apr 2, 2009 | 10:13 AM
JKCANADA's Avatar
I don't know if it'd be any cheaper, but there's alot of aftermarket glass companies.. If you have a "speedy glass" or "windshield world" or something around, maybe you should check prices with them?
Old Apr 2, 2009 | 10:14 AM
JKCANADA's Avatar
as for the dent, I've been sitting at the computer too long... I can't remember what the inside of the door looks like now.. If the panel is removed, can the dent maybe be pushed from the inside?
Old Apr 2, 2009 | 10:19 AM
James76's Avatar
NORMALLY its a royal PITA to remove the door panel because the window is attached to the inner panel. But if its completely broken, should be very easy to remove and replace. If i had known it was that cheap i woulda just busted the darn windows out when i did my door lock actuators
