Windshield Pillar Lights
Old Nov 16, 2007 | 10:42 AM
  #51
seer1's Avatar
Originally Posted by RubiEngr
I love the way that these lights look. I defiantly want to install lights there, however this is my first jeep and I haven't done anything like that before. I have seen other people ask how you did this but I haven't seen a response to those questions yet (maybe I have been looking in the wrong place).
Could anyone tell me how you ran the wiring for these lights, I don't think it is too complicated.
also I would like to locate the switch on the lower center console using the cooltech switch plate. Here I just wanted to know how much I would have to remove of the center dash to get the wires there.
Any help would be greatly appreciated.
Welcome to the Forum. If you pull the four allen bolts that hold the center cowl down you'll be able to lift the cowl up enough to slip the wires through. Get the kit as VaughnJK suggested and it'll have everything you need. You'll find the wires route easily from the battery/relay/fuse holder around the vertical piece of sheet metal and into the area under that cowl. Be sure not to over tighten those bolts or you'll strip out the sheet metal.
The biggest PITA will be running the wires into the interior. Some folks punched a hole somewhere in the engine comp heat shielding where there is a pre-existing hole. I punched a hole in the grommet located under the battery tray where a wiring harness runs through the firewall. Once the two wires are through that it's fairly easy to string them under the passenger side dash to the center. If you pull the carpet back around the center dash/console you'll find a bolt/ bracket that holds down that center dashboard. It is a perfect place to hook your ground wire to.
The CoolTech switchplate is a piece of cake to hook up. Hint: If you have an AT, before you start, turn the key to the ON postion, shift down to drive 1 and pull the 4wd lever into 4 lo. Then yank the negative cable from tha battery. You'll need that room to work. The instructions from the kit should take you from there. Good luck.
[IMG][/IMG]
Old Nov 16, 2007 | 01:58 PM
  #52
vaughnJK's Avatar
Originally Posted by CLACKEY(_!_)
When I hit my high beams I also get the spots! Illegal as hell......kinda.
Does that help?
I think I read something about that mentioned somewhere, but I couldn't find it for my state. How would one find the legalities of the kc's and the road?
Old Nov 16, 2007 | 02:04 PM
  #53
CLACKEY(_!_)'s Avatar
In california you can get access on the dmv website. For California it stated that they need to be on a seperate switch. Technically mine are. It also states they need an opaque cover which I do not have. The only thing I get from the coppers are &
Old Nov 18, 2007 | 07:46 AM
  #54
vaughnJK's Avatar
What are you guys using as a padding between the brackets and the paint? I have some thin rubber washers in the tool box, but I'm not too sure thats gonna cut it.
Old Nov 18, 2007 | 10:17 AM
  #55
vaughnJK's Avatar
Originally Posted by putnam dan
Padding - why?
To prevent scratching the paint. I've seen someone mention it somewhere.
Old Nov 28, 2007 | 10:58 AM
  #56
RubiEngr's Avatar
Thanks for the info. Now I just have to decide what lights i want to use on the pillars.
Old Jan 13, 2008 | 12:05 PM
  #57
moonman's Avatar
The brackets are from Mopar. I bought them from my Jeep dealer. $92. At first I was not sure if I liked them, especially for the price. I did not like my other options though. The Warriar brackets seem to put the light up and in. These are out and down.
I like thee mounts and lights....looks great
Old Jan 13, 2008 | 02:47 PM
  #58
Littlejon's Avatar
I really like the out and down look of the mopar brackets.
Old Jan 13, 2008 | 02:53 PM
  #59
BaltChief's Avatar
If you mount lights on the bumper and the windsheild, can you use the same relay or do you need to have a seperate relay and switch?
Old Jan 13, 2008 | 03:23 PM
  #60
mattythreeputt's Avatar
i have the kc slimlights on my rubi. when they are on I get light shining through between the light and the cover back into the winshield. any suggestions?
