wish me luck
Old May 15, 2009 | 01:44 PM
blk08wrangler's Avatar
Default wish me luck
ok well after haveing the teraflex 2.5" bb sitting in my spare room collecting dust for the past month or so im gonna get it put on tomorrow with the help of a couple buddies. ive read countless threads on the kit and im not really worried about the install. the only thing is i guess i dont want my esp to be fubar'd but fingers crossed ill have no problems.
i have a pic here of what my kit included. does it look like everything is there?
wish me luck ill start the install around 10am tomorrow and hopefully be drinking beers mid afternoon haha
Old May 15, 2009 | 01:51 PM
TeraFlex's Avatar
Sponsoring Manufacturer
Looks like everything is there! Good luck!
Old May 15, 2009 | 01:53 PM
river2c's Avatar
Very easy install and it won't affect your esp. Just don't overextend your brake lines when you jack it up and lower the axles. Unscrew the rear bracket securing the brake lines to the underside of the tub (like the directions state) before you lower the axles.
Old May 15, 2009 | 01:59 PM
Doc_D's Avatar
Good luck! You should be fine. I've been working all day on putting my 3" teraflex with full flex arms and adjustable front and rear trackbars on. I'm just about done with the back and everything is going suprisingly smoothly.
Old May 15, 2009 | 03:22 PM
greenamphibious's Avatar
cake walk!
Old May 15, 2009 | 03:35 PM
falconfixer's Avatar
Make sure you got some white lithium
Old May 15, 2009 | 04:16 PM
JK Rocker's Avatar
Yep. Gotta give those zirks a squirt.
One hiccup I had on my install was over tightening the zirks on the sway bar link. They have to be slightly loose to accept grease. I tightened them, then alternated between loosening a turn and trying the grease gun. A little trial and error, but I got em greased eventually.
Old May 15, 2009 | 04:42 PM
rjhoop's Avatar
mine was easy when i did it (my first lift) took about 3 hours my first time.now that ive done it and know what i need to do it i could probably do it in 45min to an hour its that easy!!!!
Old May 15, 2009 | 05:35 PM
Northernmedic's Avatar
Man I'm just in Fairview if you need help. I've torn these suspensions apart many times. We got to get together one of these days and wheel
Old May 15, 2009 | 05:50 PM
mkjeep's Avatar
Remember to take your tranny skid and crossmember off to allow the frt to droop far enough so your drive shaft don't hit it, uh don't ask me how I know that Gotta friend coming over to help with BB on a 06 rubicon tomorrow. Must be a BB&B weekend( budget boost & beer)
