witch tie rod to get
In the market for a new tie rod was thinking about the synergy or Rock krawler what are people on here running I am also running 16s
I've been running synergy up front for about a 1.5 years now and everything is rock solid. Easy to adjust and greaseable, really nice setup. I have their draglink flip kit as well and I would recommend it if your rig has a sizable lift.
I can't speak for many other companies, but I just received my Synergy tie rod last week. Easy install, on vehicle adjustment, and even though it is much stronger than the stock tie rod (and much heavier), it is still the same diameter so there isn't the necessity to purchase an aftermarket steering stabilizer mount. I have other Synergy parts and have never been disappointed. Again, I haven't driven any other tie rods, so I'm not saying it's the best, but I am happy with my purchase.
Synergy is a good choice and is what I run. This TR is easy to adjust. If you go with their DL, then you only need to carry 1 TRE as a spare, as it will fit all both ends of the DL as well as the TR.
Good luck.
Good luck.
I'll throw this out there, too. I have synergy and I'm very happy with it! I would have also looked at rock krawler 's but it wouldn't work with the backspacing on my wheels.
