Wobble over bumps
Old Feb 15, 2013 | 07:56 PM
Biglew81's Avatar
Default Wobble over bumps
Here recently I've noticed a wobble in the front end when I hit bumps at speeds above 30mph it seeming to be getting worse my vehicle is a 12 JK 2 door with 14K miles. It's got a three inch lift, any ideas or input is greatly appreciated. Also it seems to be worse if just one front tire hits the bump or hole as opposed to both front tires hitting the bump or hole. Thanks in advance.
Old Feb 15, 2013 | 11:08 PM
Gstoner18's Avatar
Mine was doing the same thing. I just had my front end realigned and it fixed it.
Old Feb 15, 2013 | 11:28 PM
Omani2010's Avatar
Could be ur tires
Old Feb 15, 2013 | 11:55 PM
MitchMG's Avatar
I just wanted to start a similar thread. Altough I wouldn´t say wobble. I would call it shivering.
Drive over dirt roads or streets with potholes you fell after a pothole a sort of shivering in the suspension.
I seems some parts are to weak or so. Like The shocks shafts, or control arms or bushings are to weak / to soft.
Or maybe the shock doesn´t have enough rebound for the spring rate.
Is this the same ???
And what is the solution ?
I mean depending on the parts which might be to weak I´ll spent my next money.
Anyway I´m looking for ne shocks. Probably Fox 2.0 factory or If I got enough money King 2.5 OEM
If CA are to weak I might buy them first.
