Wrangler MT/R's?
Old Aug 23, 2008 | 09:20 AM
  #21
Henthorn's Avatar
Originally Posted by Hellbilly
Wha? Uh, OK All I KNOW(not assuming or guessing, you know because I run em) is that they are the best tire that I have run on any of my jeeps. Also, I said I run 315/75/16(just shy of 35's), Anyone running a trail 4.0 or more is probably running a bigger tire Does MTR come any bigger than 37? Idunno, but maybe a 40 at the most. What size tires do you see on your 4.0 trails in Arizona? Guess I'll stick with my little bity North Carolina trails
and we'll stick with our little bitty Arizona trails.
Phots courtesy of Lance and the bunch at Azvjc
Oh, and Lance is running 37's.......
Old Aug 23, 2008 | 05:02 PM
  #22
Ryanm's Avatar
What is the recommendation for inflation pressure in the 37" MTRs? I know the max is 65, which seems insane. What are most people running in them day-to-day?
Old Aug 23, 2008 | 05:06 PM
  #23
Henthorn's Avatar
for street people seem to be running about a pound per inch... IE I have 33's and 33-35 psi is great for street, gas milage... I air down to around 12psi while on the trail though
Old Aug 23, 2008 | 05:09 PM
  #24
Hellbilly's Avatar
Your right, I'm wrong. I'm taking my tires off right now. What are you running, thats what I want. I want your tires. Tell us what tire you run, and what all you know about your tires. Bet they are friggin the heat at the mallYou win bud. I am just a new jeeper and your the trail master I am not worthy
Old Aug 23, 2008 | 05:49 PM
  #25
Ryanm's Avatar
I think the pound per inch is for the C-load rated tires, the 37s are E rated with a max pressure of 65. I'm guessing they need to be in the 40s, but that still seems low in comparison to its max pressure.
Old Aug 23, 2008 | 06:06 PM
  #26
Henthorn's Avatar
Im running MTZ's.
And only reason im staying at 33's is in case I get stationed someplace away from the trails, it'll be at least drivable with decent mileage without having to take the tires off. Im up for a PCS in November of this year. It would suck to get stationed someplace like new jersey :( but its a possibility and untill I get out of the military, its something I need to factor in.
In the pic above lance is running Baja Claws in the competition compound...(I dont think they make it any more, and even if they do---his IS a trailer queen--competition tires would wear down way to quick)
40PSI seems way to much RyanM--honestly the best thing to do is use the chalk method, simpley because everyone's rig is going to weigh more and tires are going to flex(more or less depending on manufacture and weight of jeep)
Take a chalk line, inflate to what you think max should be for your rig, drive streight and see where the chalk is rubbed off.. If just in the center of the tire, you need to let air out. if it starts to get to the edges, add more.. your looking for a nice even wear across the line. Dont forget that you need to drive streight for this to work, as turning will distort the line..
Also dont be surprised if the psi needed in the front is higher than the rear..
Old Aug 23, 2008 | 06:09 PM
  #27
cojk's Avatar
Default Goodyear MT/R's
I've been running them for about a year now, really like them. Work great on slickrock crawling in Moab. Good all around tire.
Old Aug 24, 2008 | 03:10 PM
  #28
coachfb6821's Avatar
Anyone have issues with them in the snow? I love the Jeep in the winter here in OH and I hope these wont make passing those H3's anymore risky....
