Wtf?
Old Apr 25, 2009 | 04:59 PM
mkjeep's Avatar
Are you talking about the upper control arm axle end?
Old Apr 25, 2009 | 05:09 PM
smuhhh's Avatar
I think so. I'm gunna level with ya, I didn't even know what a control arm was until about a week ago. It is literally impossible to tighten that bolt with the tire on though.
Old Apr 25, 2009 | 05:14 PM
mkjeep's Avatar
Do you have spacers on , or are you running stock rims? If it were me and I may get flamed , I'd torque it with it jacked up. Think the uppers only require 70-75ft lbs, lowers 125ft lbs. The lowers and the trk bar are the major torquer's.
Old Apr 25, 2009 | 05:19 PM
mkjeep's Avatar
It seems as if it's the upper CTRL ARM axle mount trhat your are referring to. Just use an end wrench and cheater pipe . I'm guessing you can't get the torque wrench on either side. Tighten like a sumbitch, as Redneck would say.
Old Apr 25, 2009 | 05:27 PM
smuhhh's Avatar
alright i got er done. I was pretty mad for a minute there... but that has passed. I'm almost 7 hours into this, and I'm just starting the front. I guess I shouldn't have tried to do this solo becuase apparently I'm borderline retarded.
Old Apr 25, 2009 | 05:31 PM
RedneckJeep's Avatar
I did mine and all I had to do was remove the sway bar end links, shocks, drop the axle down and the springs fell out. I didn't touch the control arm bolts or the track bar bolts.
Old Apr 25, 2009 | 05:32 PM
bly109's Avatar
rear uppers, rear lowers and front lowers are 125; front uppers are 75
