x vs. rubicon suspension question
Slightly off topic -
I just traded in a Sahara on an 09 Rubicon and they were the same height sitting side by side. There was a base X with steel wheels nearby and it looked noticably shorter. Now I wish I would have measured!
This thread should settle the spring issue:
https://www.jk-forum.com/forums/stock-jk-tech-12/lets-solve-stock-springs-question-85825/
Some of the X models have the exact same spring p/n as the Rubi. The only place clearance can come from is from tire size. Tire sizes available in 2008 (2007 and 2009 may be different) and the axle Ground Clearance relative to the Rubi:
Model: X
Tire Size: P225/75R16
Height in Inches: 29 5/16
Ground Clearance: -1 3/8
Model: X
Tire Size: P245/75R16
Height in Inches: 30 7/16
Ground Clearance: -13/16
Model: X
Tire Size: P255/75R17
Height in Inches: 32 1/16
Model: Rubicon
Tire Size: LT255/75R17
The bottom line is it is incorrect to state the Rubi has 1" clearance over the X. The springs vary between models and options with some of the same springs being used on both the X and the Rubi. The tires may make over an inch of axle clearance depending on which X model and options were selected, but does nothing for fender clearance.
Model: X
Model: X
Model: X
Model: Rubicon
See my post https://www.jk-forum.com/forums/showthread.php?t=85825
Lets solve the stock springs question
Heres the deal.
If you have a jeep with an F in the fourth place on your vin your GVW is 4000 to 5000 pounds.
If you have a jeep with a G in the fourth place on your vin your GVW is 5000 to 6000 pounds.
There are a lot of spring combinations out there from the factory.
If you have a G vehicle, going to any other stock spring set will not help and may move you backwards.
If you have an F vehicle going to G springs will allow you to increase your GVW without making the jeep sag.
If you go from an F 2 door to G Rubicon four door springs, especially if the four door had the towing option you will see an increase in stiffness and you may gain a bit until you load yours up.
I have a set of Rubicon G four door springs that I put side by side with my X 2 door F and they are an easy inch taller.
Heres the deal.
Heres the deal.
Heres the deal.
This was also accompanied by an immediate improvement in handling and totally did away with a bottoming out problem in the rear end.
I have since added a 2" spacer lift and 275/85R16 ProComp Extreme AT's and it ROCKS!
I'll I was trying to point out is there is no hard-and-fast "the Rubi is an inch higher than the X". Might be. Might even be more. Also, though, might not be. A "G" X with 255/75R17 tires will be +/- the loaded weight difference of a Rubi. In fact, but the time you factor in the Rock Rails, eDisco, and other weight adders, I would bet an unloaded X with an empty tank of gas would be considerably higher than a fully loaded Rubi with a full tank. OK. Unfair comparison. But you get the drift?
Although, it does look like Rubi's generally have the higher spring part numbers. Based on what I've seen so far, it wouldn't be worth a swap unless you're going to increase the spring part number by 2...ie., swapping a 14AB and 15AB set of springs for 16AB+ and 17AB+ springs.
I would assume the same for the rears.
However on the TJ forums there are plenty of threads asking if the Rubicon springs will lift an x, and the answer is the same as here on the JK forum.
I have both a 2009 Rubicon Unlimited 4dr and a 2008 Unlimited X 4dr both have 32" tires and 17" rims. The tread on the Rubi is more aggressive. The X has the heavy duty suspension. The Rubi is 3/4" taller at mid door.
Still too many variables to be a conclusive statement!
BTW - I'm extremely jealous you have TWO Unlimiteds!!
Yes and no, it depends what your talking about. Lets talk about what a lift does. If you put a 2.5 bb (spacers above stock springs) on a rubicon it will raise the frame 2.5 inches higher above the axles. The same 2.5 bb on an x will have the same effect, it will raise the frame 2.5 inches higher off the axles. Now if you want to compare actual height of the frame relative to the ground then yes, the rubi will sit taller cause the stock springs are taller. This is why some people can fit 35's with a 2.5 bb while others can't. Now if you go with the 2.5 coil lift, or any coil lift for that matter, it doesn't matter what model you have cause the springs are being replaced, so overall height from ground to framer should match (unless one is loaded with weight from a winch bumper, gas cans ect.).
Back to your original question I'm a little confused. Are you talking about doing a rubi spring swap plus a bb?
this doesnt call for any extra work though does it?
