Yet another axle thread.
So what I'm seeing from the general consensus is, get a crate rubi 44, beer it up with quality instillation, and put some thought into the other components of the axle like ball joints and shit.
If you can get the axle for a decent price (under 2k vs the more normal 3k+). And if you get the regear for a decent price (some people, mainly east coast, are being quoted over 3k for gears). And if you get the strength mods/welding for a decent price (labor rates and individual skills vary, be sure to ask around).
A few years back when I was in the market to replace my broke d30, everybody wanted a premium price for the front rubi axles. After having a shop I trust do the gears and strength upgrades, a pr was only a few hundred more than what I came up with for buying and building a rubi44, and the PR came with the caster correction - which I kinda like.
So I guess the moral or the story is: Unless you are doing the work yourself, you need to check your local shops and come up with a total price to compare to the roughly 5k of a pr/tera. With these ebay prices and decent local rates, the crate rubi could be an excellent deal. Or it may not.
And one other comment on the ebay axles. When you talk to the guy, you might also ask if the stock balljoints are already installed, or if it is possible to get it without (or with the upgrades of your choice)
I have the welding equipment, so I picked up the gussets and sleeves. For around $2000 I will have a nice setup. Plus, I was originally planning to swap the gears on my stock D30 for $800, so this is a great option for an extra $900 and it has the locker.
I bought a Rubi axle from this guy 2 weeks ago with 4.56 gears for $1700. Should ship any day. Spoke with him on the phone and he is a super nice guy. He texted me a photo of the gears to let me know they arrived (they were Yukon). He told me he could swap the gears and ship within 2 weeks, but I told him no hurry.
IF you are going to run that big a tire and wheel it you should expect to run tons and hydraulic assist on the steering. Like others have said you will just be wasting money on upgrading the factory stuff and a Prorock 44 is a poor choice buying new.
38" tires on a 2007-2011 automatic is going to suck as well as there just is not enough HP if you are going to be driving in the mountains. Big tires cost money, not just in the rubber themselves but everything you need to do underneath to accommodate them. If money is an issue I would rethink the goal of running 38's. I am not trying to be a downer, just a realist, but people come on the forums all the time trying to justify how they can run with the big rubber for little or no money. I also see many of those that have done the upgraded 30, moved to rubi 44, moved to PR44 eventually go with tons in the end.
Is there a particular donor vehicle I should look for?
Thank you.
Several local guys around me have bought new crate Rubi 44s. There is a guy in OH selling them (complete) for around $1700. They brought them by my place, I welded on Artec armor, installed the axles, and then sleeved them. So, they have beefed up 44s for under $2k. At that point, the housing is the last think I worry about. One of those guys was running a different gear ration than 4.10. so he had a local place do a regear. Since it was new, it was only around $350 all in. That said, I thought I heard the guy selling could offer different ratios with some amount of lead time.
As noted, I personally worked on two of the axles this guy sells. They are OEM housings, with serial numbers and identification. Sure that can all be knocked off, but one thing can't. The external locker connectors are from the factory. I can tell you with 100% certainty, that Chrysler is the only company with access to the unique, one-off sensors. There are just far too many little details for someone in China to replicate it, ship it to the US and still make a dollar.
If done right, it should go fine. Run 1" stitch welds, move around a lot. Don't over weld it (you don't need to weld every inch of the truss, except at the axle). And use a good welding blanket so it cools very slowly (better yet, pack sand around it if there is a way you can do that).
We made a tension rack in an abundance of caution. Basically, we picked up a piece of steel beam, put jack stands over it and the axle on the jack stands, chained the axle ends to the beam and used a bottle jack on the diff to put upward pressure on it. It's actually a really cheap setup as you probably have everything but the beam. I'd bet you could pick one up from a steel supply as a rem for cheap.
