Your thoughts on these rims
Old Aug 8, 2009 | 06:17 AM
CJ7nvrstk's Avatar
Vet Army
Default Your thoughts on these rims
I'm thinking of going to 15x10 rims and 35's. After going thru all the posts on 15" rims over the last week or so I was leaning towards 3.75" backspacing and hoping to avoid having to grind brake calipers. What are your thoughts on these rims?
.summitracing.com/parts/CRR-3655150/
Or these
summitracing.com/parts/CRR-3105150
I would painting these OD green.
Any thoughts on fitment or has anyone tried these particular rims? (Either one) If so, any fitment issues? I couldn't see where anyone was actually running these particular rims tho I may have missed it.
Was thinking of just ordering one rim and test fitting unless I can find someplace local that has these exact wheels and do a test fit there first.
I had figured on trying these because I noticed that people running Cragers generally had to grind the calipers but it seemed they had 4" backspacing and thought that with these being 3.75 I would be able to avoid that.
Your thoughts?
Old Aug 9, 2009 | 06:15 AM
CJ7nvrstk's Avatar
Vet Army
Thanks for the input. I just ordered 1 of the Cragar 365 V-5 Series Wheels, a blem from Jegs. Will test fit when it gets here and let y'all know.
Old Aug 9, 2009 | 10:24 AM
TxCop07's Avatar
Vet Army
That is the wheel that I want to go with. PM me when you have some results.
Old Aug 10, 2009 | 02:21 PM
CJ7nvrstk's Avatar
Vet Army
Originally Posted by planman
Just a heads up, before they mount tires to those wheels, have the tire shop run them on their balancer to make sure the blem is not a bent wheel.
Sometimes steel wheels are not 100% true (without a bend or wobble). A little bend or wobble can be fixed with balancing weights. I bigger bend or wobble cannot be compensated for. As long as 4 of the 5 wheels are good, you can have the one requiring more weights as your spare.
Was planning on doing my test fit without a tire on the rim. Don't even have tires yet.
BTW, blems are supposed to be cosmetic in nature only. No biggie for me since I will be sure to bash em up anyways. Was planning on using this one as a spare anyways for the time being as I still have a stocker on the tailgate. Will be checking it out for trueness though, thanks.
Old Aug 13, 2009 | 10:11 PM
jeepnyak's Avatar
did you test fit yet? check balance?
Old Aug 15, 2009 | 04:55 AM
CJ7nvrstk's Avatar
Vet Army
Gonna do that today. Typical blems, are true with slight cosmetic imperfections.
Old Aug 15, 2009 | 06:20 AM
CJ7nvrstk's Avatar
Vet Army
Damn! The Cragar 365 V-5 in 15x10 and 3.75" backspacing rub on the front calipers. As I am not comfortable griding on the calipers of a Jeep that is 1 year old and still under warranty, I will not be running these.
PM's sent as requested
Old Aug 15, 2009 | 07:46 AM
RedneckJeep's Avatar
Black Rock Wheels (which are made by Cragar), has a JK specific part number almost identical to that first one that will fit with NO grinding whatsoever. They are here:
http://www.quadratec.com/products/92613_02XX_A_PG.htm
Also on a side note......Hummers have "rims", Jeeps have "wheels".
Old Aug 15, 2009 | 11:54 AM
Chicken Corners's Avatar
Redneckjeep, that link is to 16in rims, he is looking for 15in rims. Does Crager also make that in a 15in?
Old Aug 16, 2009 | 05:15 AM
CJ7nvrstk's Avatar
Vet Army
What chicken said.
As for the rims/wheels thing:
You may say "democrat", and I may say "Worthless tree huggin, birkenstock wearing, kumbaya singin, bleeding heart, not worthy to drink the toilet water of our Service Members, tax raising, coolaid drinking, self serving, elitist liberal."
For the most part, same same.
