New England If you live in the New England area (Maine, New Hampshire, Vermont, Massachusetts, Rhode Island, and Connecticut) and would like to meet some of the great JK-Forum members in your area and/or discuss upcoming trail events, this is the forum for you.
Busted Driveshaft - Help!
Old Nov 27, 2011 | 09:19 AM
MarbleheadGuy's Avatar
Default Busted Driveshaft - Help!
gone
Old Nov 27, 2011 | 11:32 AM
Bosox5's Avatar
Veteran: Coast Guard
how far from work are you? I would pull it if its not too far, and run it in 4HI and just be easy on it. not hard to pull it, pretty sure all the bolts are 8mm? A ratcheting wrench will make quick work of them. The hardest part will be getting the flange out of the diff end, get a punch and you will see some small holes in the back of the diff where you can hammer the punch till the flange pops out of the diff.
Old Nov 27, 2011 | 11:47 AM
helnbk's Avatar
I had the same problem a few years back and just took my rear DS off. I drove around in 4H for a couple of weeks, just be carefull turning corners and take it easy, just like the poster above me mentioned.
I ended up ordering a Tatton DS, they were the cheapest, and have a great reputation.
Old Nov 27, 2011 | 12:17 PM
Bosox5's Avatar
Originally Posted by MarbleheadGuy
I'm about 20 miles from work. Yeah I got all the bolts out but couldn't budge it out of the diff end - seems rusted in place pretty tight. If I could jack it up I could get more leverage with a rubber mallet. Do you install a new DS the same way you take it off? Is it really that easy?? What kind do you recommend Mike?
get a punch, a thin one and put in threw the holes in the back of the diff and slam on them with a hammer till the flange pops out. It is the same way, the ds will only attach one way to each end.
Old Nov 27, 2011 | 12:34 PM
Bosox5's Avatar
let me know if you can't get it, I can drop by after work and help you get it out.
Old Nov 27, 2011 | 12:37 PM
helnbk's Avatar
I'm gonna try my luck getting this covered by Chrysler.
"I was just driving along the highway and hit a pot hole!"
We'll see if that works first before dropping $600+
You can get a new DS for about $400.
Old Nov 27, 2011 | 12:53 PM
petef550's Avatar
Hey Greg I hope you wash all that mud off before you go to the dealer just kidding. That really sucks good luck with the dealer
Old Nov 27, 2011 | 01:02 PM
sneck's Avatar
yeah I have a dealer less than 5 minutes away, I just pop in and ask "will you fix this" before ordering anything.....
I can't believe they wouldn't replace my steering stabilizer!
Old Nov 27, 2011 | 02:06 PM
mostly stock's Avatar
Take the rear shaft out drive in 4wd high on front shaft. You'll be okay for awhile. Peace.
Old Nov 27, 2011 | 03:00 PM
ssgthooligan's Avatar
I have an extra driveshaft for the rear.
