New to jeeps, '13 Rubi, and lift question
Hello JK forums, I bought a new white rubicon 2 Dr 6 speed on Saturday.
And after driving it in the last snow storm here in Utah, I LOVE IT. Never had to put it in 4 wheel and my big bad ass bronco would have needed to.
Since I'm a jeep noob help me out, I'm looking at a teraflex 3" lift, can I do this without worrying about steering and pinion angles?
Thanks,
Zach
Sent From My HTC One S using Tapatalk 2
Thanks,
Zach
Hello JK forums, I bought a new white rubicon 2 Dr 6 speed on Saturday. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=416123"/>
Thanks,
Zach
Thanks,
Zach
I'd highly recommend this
Front lower control arms
Rear upper control arms
Front adj Trackbar
Now after running that setup for a year and I put in a set of front and rear driveshafts my rear pinnion output seal leaked Andy front diff output seal leaked
This told Nuevo was running my 2 dr at pretty good stressed angles with stock Driveshafts. I got away with a year because isn't a DD show thing to consider later on.
My experience is this, I had no issues running a 3 inch in my 2 dr.now if you stick under 35's
Front adj Trackbar
Front adj Trackbar
To make it drive better its recommended front lowers or AEV geometry bracket
You know what, my bronco will cover will cover anything ill do to the jeep when i sell it, so i made up my mind and im going with the 3" after all. Thank you Bubba for all your in put.
Recommend front lower control arms or geometry brackets
Front adj Trackbar
Rear upper control arm to adjust rear driveshaft
I drove my awhile without and was a little flighty on freeways but not bad on two lane roads
Also if you go Teraflex I'd recommend going bilstein shocks instead of the Teraflex so order without shocks
Lastly do you have a 2012 or 2013?
Of so you need to either exhaust spacers or just a new front driveshaft to clear front cross member
