What winch should I get?
I wanted to get some opinions on what winch i should get! Here are some options I had in mind:
Superwinch LP8500
Superwinch EPi9.0 Series Master Winch ----I reallllly like this one for some reason
WARN VR8000 8,000 lb Winch
Superwinch LP10000 Winch
WARN M8000 8000-lb Winch
I dont think I will end up using the winch a whole lot, so I cant really justify spending too much. However, I do want a high quality product that will work when I need it.
Superwinch LP8500
So far, so good, with my LP series Superwinch.
I have not had it very long, or worked it to death.
The LP series allows you to get an affordable name brand winch.
Something you hopefully will not have to use often.
When they all start to look like close contenders start looking at the details like amperage draw and such and then weigh benefits vs cost.
Good Luck
Good Luck
. This problem was easily solved by putting a washer on the bolt before mounting the fairlead.You can always double check by measuring it. I think the dimensions should be something like 4.5" by 10"
Chris
