Who else's top leaks?
Old Feb 23, 2014 | 06:09 AM
Sahara_Maverick's Avatar
Originally Posted by JK-FREAK
The waterfall is considered normal, so long as it only occurs when you open the door.
Same here. Mine only "leaks" under rain when I open the doors. Then it's like I opened a dam and a waterfall pours into my Jeep.
Besides that it's very tight either with the hard top and the soft top. No water penetration at all.
One hint is to "wiggle" the freedom panels each time you put them back. This will help seating them on the seals. I droo the passenger side, wiggle it a bit and tight it. Then repeat for the driver panel. I notice both seat a bit deeper when I do so. Already went through heavy snow accumulated on top of the roof to heavy rain without a single drop into the cabin.
Old Feb 23, 2014 | 06:17 AM
Jeepstin12's Avatar
Mine did twice, early on when new. Both times it seemed the seals were compressed and I had to tighten the bolts and plastic headed bolts. Both times it fixed the issue. No leaks since.
Old Mar 6, 2014 | 06:57 AM
BradleyC's Avatar
This morning, after yesterday's big storm, I noticed that under my rubber floor mats the carpet in the front and rear is wet. The front driver and passenger are both soaked.
Would you guys agree, if I'm finding soaking wet floors in both the front and back on both sides that the leak I'm experiencing must be the fender leak described in the previously posted 'Leaks PDF' that Mopar released?
I'd think there would be a business opportunity here if someone could figure out how to solve all these leak problems...just a thought. Seems to be a lot of people complaining about this on the internet.
Old Mar 6, 2014 | 01:39 PM
mdash's Avatar
If it is the fenders leaking then they already have a fix for it. Use tape to cover the holes. Fixed! Are your rubber drain plugs still in the floor of the Jeep? Mine are removed so my carpet will get wet if I'm driving in really shitty conditions. Or maybe the water is just from opening and closing your doors.
Old Mar 6, 2014 | 09:35 PM
BradleyC's Avatar
Got home tonight after work and folded the carpet back to find multiple large puddles of water and soaked carpet and heatsheild material. Looks like it may be coming down the A or B pillar. Once the WeatherTech floor mats get here next week I may just leave the carpet out while the weather sucks. No sense in leaving the carpet in if I'll just need to keep drying it out.
The plugs are all there(atleast the front) but I have them out right now draining water. Jeep in the garage with the mats folded back airing out. Bedtred anyone?
Old Mar 6, 2014 | 10:24 PM
Ab1's Avatar
Ab1
Default Oh the leaky tops...
My 2010 JKU was bought back by Chrysler under California lemon law for leaking at the A pillars... Clearly I'm addicted to Jeeps so after a short stint away from the team I'm back and hoping for better results in a '14 Rubi... I'm pretty optimistic!
Old Mar 7, 2014 | 02:38 AM
HiHoSilver's Avatar
Mine has always leaked... I deal with it..
Old Mar 10, 2014 | 03:06 PM
Auxillaryman's Avatar
Originally Posted by Auxillaryman
My freedom panels have leaked for six months. Well when it was below freezing it didn't because it was an ice cube!
I took it in to dealer and they said they would order me a new one, that was 3 monts ago! It is taking longer to get my replacement top in than it did to order my jeep!
I guess on the bright side, I live in a very dry area of Texas...no rain in forcast...hardly ever.
So the dealership FINALLY called and told me that my replacement freedom panel was in. I tried to pick it up this weekend, but they told me that I needed an appointment...Really! So I made an appointment for today. Had the wife borrow he dad's truck and pick me up at dealership. I received a call after lunch that they had a problem. The freedom panel was not the correct one. I have a Sahara with freedom panels that match the body color and the panel they had was textured. Evidently they can't just repaint it? The service tech told me he placed the order for a new one, but didn't know how long it would take to get in. I think my jeep will be out of warranty before the part comes in. Lol. Is anyone else having problems getting driver side replacement freedom panel?
Old Mar 10, 2014 | 04:14 PM
double J's Avatar
I had problems with water running down between my windshield and door to my door sill. I applied SIL-GLYDE on my door seals and it helped my problems. It only does this now if the door is open too long when it is raining.
