UPGRADING TO 37"s! NEED HELP!!
Old 01-31-2019, 07:37 PM
EthanS's Avatar
Question UPGRADING TO 37"s! NEED HELP!!
I want to get 37" tires with at least a 4 inch lift. I need to know what else I NEED for my 2012 Unlimited Sport (Manual). Only want to know what is required to make sure the jeep stays safe and durable, Any suggestions will help.
Thanks
Old 01-31-2019, 10:04 PM
nthinuf's Avatar
There are a few threads stuck to the top of the Modified JK Tech section. Start there.
The only thing you NEED for a 4" lift is 4" coils or spacers. But, there are many things you will likely WANT...
Rims/adapters that net a backspace in the 3-4" range. Longer shocks. Adjustable trackbars to center both axles. A rear raised trackbar bracket might be a good call, as would steering correction up front (draglink flip, high steer, drop pitman - research the pro's/con's). Some type of correction for the caster/pinion. (Cams, fixed control arms, adjustable control arms, brackets - research the pro's/con's). Longer swaybar links/disconnects. Bumpstops to keep the tires from moving up into the flares. Longer brakelines / brackets. Gears for both axles. (may as well consider installing traction at the same time.) Put money aside to replace the front driveshaft, balljoints, the rest of the steering components, etc, etc, etc...
But yeah, the only thing you actually NEED is the coils or spacers.
Old 02-01-2019, 06:22 AM
Ghost JK's Avatar
Might also want to look at either a D44 for the front or dumping some money to beef up the 30 you have. Sleeves, truss, gussets on the C's. 37's are quite a bit of stress to put on that axle.
Old 02-01-2019, 06:39 AM
I agree with what nthinuf already said.
What I would stress that you don’t NEED 4” to run 37s, and tbh, the higher you go the less favors you’re doing yourself. IDK why everyone tends to think higher is better. You may like the “look” of higher, but it gets less functional as your center of gravity is going up. You are actually just decreasing performance IMO.
So, with 37s, you need to think about these things:
  • You’ll most likely have to regear, which means adding a programmer as well if you don’t already have one
    • This could lead you down the whole “do I want to add lockers or not at the same time
      • Which will lead you down the rabbit hole of WHICH lockers
        • Which could lead you down the path or replacing axle shafts to match new locker spline count
        • Which could lead you down the path of is putting money in to a D30 worthwhile
  • ​​​​​​​You’ll probably need new rear axle shafts as the factory flanges tend to bend easily with 37s (even if you don’t off road)
  • 3.5” BS is most appropriate for 37s, and you’re not going to find many non-beadlock options with that BS
    • You can indeed run spacers…..those can get to be a drag if you do much work on your jeep IMO
      • If you have spacers, many tire shops won’t touch your vehicle. This depends on location usually.
      • If you have beadlocks, many shops won’t touch your vehicle. This depends on location usually.
  • You’d better factor in some expensive ball joints, Rare Parts would be your best option
    • Factory BJs ain’t gonna hold up, and if you wheel, odds of TF, Synergy, Alloy….they’re all a crapshoot
    • I cannot recommend DT at all. You can search up my thread on rebuilding those….not worthwhile.
  • Plan on new drive shaft if lifting 3”+, or at the VERY lease rebuilding a factory shaft using the TF high angle rzeppa.
    • Boot at the TC-side CV joint will rip, spew all the grease, and the joint will dry out leading to early failure
  • With 37s and 3”+ lift, you really need to have a full set of control arms IMO.
    • Especially in the rear, you’re gonna want the ability to move the axle back again as the tire really creeps forward in the wheel well
      • Even with significant trimming of the pinch seam, which you’re gonna have to do, you’ll probably want more clearance
        • Pushing the axle back will probably require you to relocate or remove your rear sway bar back an inch
          • Relocating your rear sway bar will probably force you to address the factory muffler
            • If you relocate the muffler to between the axles, you’ll need to address evap canister
  • If you wheel, you’ll probably need to address your exhaust crossover up front.
    • Exhaust spacers are a bandaid IMO
  • You may likely want to upgrade your brakes, and will be deciding between big brake kits and big rotor kits
  • You’ll address every steering and suspension component as already mentioned. TR, DL, TB, control arms, springs, shocks, bump stops, sway links, brake lines, etc.
  • Probably want to add C gussets at the very least if you don’t have em already
I mean, the list goes on and on. I know there’s more stuff I'm forgetting at the moment…..this is just quick “off the top of my head” stuff. In all honestly, if you’re building a 3.5” lift with 37s, you need to be expecting to commit ~$10k or more to it. You can’t do it cheap or else you’re going to end up with a turd that is constantly frustrating you. You just really need to consider EVERYTHING that goes in to a build, otherwise stuff is going to sneak up on you and you'll feel like you're constantly bleeding money.
The following 3 users liked this post by resharp001:
bwootters (08-27-2022), Maui BeachBum (12-17-2020), Ridonkulus (06-09-2020)
Old 02-01-2019, 06:55 AM
TheDirtman's Avatar
He said "need" but also says "safe and durable". Safe and durable is pretty much everything under the tub with 37's and 4" of lift. Resharp001 nailed it in his post and the $10k+ cost is no lie. IF you are looking at $500 4" lifts then quit as they don't even come close to what you need for a reliable safe set up and will spend endless time and money getting it to drive well. Gears, wheels, and driveshafts are often overlooked things you need running 37's on 4" of lift. That right there is $3500-$4000. Most people that do gears will also add lockers which can run you $500-$2k. You don't need those but they will offer you one of the biggest gains in pereormcane if you go off road.
Old 02-01-2019, 07:38 AM
BoraBora's Avatar
Resharp nailed it.
Your stock D30 front axle isn't worth putting any money into. Don't think slapping an Artec armor kit on it will suddenly make it a tank...it won't. 4" is also a TON of lift, and will only complicate this further. You should ideally stay around 2.5-3" of lift.
I'm assuming you're new to Jeeps? Don't think that you need 37's, because you don't. A solid setup rig on 35's will go almost anywhere a rig on 37's will go. Start with 35's and build your way up. As you wheel it, you'll find your limitations. Assess and upgrade when the time comes. $10k may be a slightly conservative figure.
To bounce off what resharp said, you'll need:
  • A proper front axle that can actually handle your 37's. A D30 will hold for some time, but it's like putting a bandaid on a cut that requires stitches.
  • 3.5" backspaced wheels - cost too variable
  • Full set of control arms ~$1000-1200
    • At the LEAST you need the front lowers, rear lowers, and rear uppers. Over 3" you really should have them all though.
  • Trim the rear pinch seam AND the rear wheel well
    • Especially when you re-center that rear axle with adjustable control arms. You'll need to flex it out and chop/grind the rear part of the wheel well to avoid cutting up your tires.
  • Your rear driveshaft will grenade real quick. Factor in a new 1310 (Adams, Tom Woods, etc.) ~$450
  • Front driveshaft will fail pretty soon when you flex it out/wheel it. Same deal as above ~$450
  • Extended brake lines ~$130
  • Chromoly rear axle shafts (Ten Factory, RCV, G2, etc.) ~$450-1000 depending on brand
  • Gears (4.88 or 5.13 would be most appropriate) ~$1000-1400
  • Lockers (would be foolish not to do this with the gears) ~$1000 each, so x2 = $2000
  • Raised rear track bar bracket ~$90-140 (weld on vs bolt on)
    • + cost of welding labor if you don't weld. Yes, you should go the welded bracket route.
  • Front and rear adjustable track bars ~$300
  • If you go 4" of lift, you'll need to address your steering. Drag link flip kit (with the raised track bar bracket) ~$250-350
    • + cost of welding labor if you don't weld. Yes, again, you should go the welded bracket route.
  • Beefy tie rod to accompany your new drag link ~$200-500
  • Ball joints ~$200-600
    • ​​​​​​​If you're dead set on 37's, you'll want the Rare Parts. So $550-600 is the more realistic figure.
  • Coils, and shocks that are the proper length (i.e. don't buy shocks based off "lift height," MEASURE!!) ​​​​​​​cost too variable, but if you set it up right it'll be ~$700+
  • Bump stops ~$cheap
  • Quick disconnects ~$140
  • Some kind of programmer (AEV pro cal, Superchips, etc) ~$150
Total (on the conservative end), not factoring in the cost of tires, wheels, or a new front axle: $7,550
Optional, but highly recommended:
  • Artec armor kit (truss, gussets, CA skids) - ~$300
    • ​​​​​​​+ cost of welding labor if you don't do it yourself
  • Rear axle truss ~$100-180​​​​​​​
  • ​​​​​​​Oil pan skid of some sort ~$140
  • Differential covers (front and rear) ~$200
New total: $8,300
Average cost of (5) 37's: $2k
5 normal wheels: $ variable
$10k +
I have an Excel spreadsheet for my build that I can personally share with you if you would like. Just PM me your email. At the end of the day, I'm just under $20k in the hole in parts. Don't forget all the other things you'll want like bumpers, armor/rock sliders, a winch, on-board air, tire carrier, etc. Still, unless you're jumping to 60's (junkyard build or brand new crate axles)...there's a pretty solid chance you'll still break something. Nothing is bullet proof.
The following 3 users liked this post by BoraBora:
Eric Groenberg (04-13-2020), Hrdtyme (06-11-2019), WaterRat72 (04-13-2020)
Old 02-01-2019, 08:10 AM
This has to be very overwhelming for a lot of people to take in.
The following 2 users liked this post by resharp001:
bwootters (08-27-2022), Plumcrazy (05-11-2021)
Old 02-01-2019, 02:24 PM
RedRubycon's Avatar
This whole list right here is exactly why I intend to stick to 35's and minimal lift...
Nathan Padilla (02-02-2021)
Old 02-01-2019, 06:07 PM
billet rubi's Avatar
One thing most have forgotten, you will need to start looking into a new upgraded steering gear box. You have a good chance of breaking the sector shaft off at the pitman arm if you aren't careful
Old 02-02-2019, 12:19 PM
spinuck's Avatar
May be why he never responded lol.
He didn't say he intends to off road it. Guessing he just wants the look.
Quick Reply: UPGRADING TO 37"s! NEED HELP!!
