Door Ajar Sensor?
Door Ajar Sensor?
I've seen a few posts on this, so it seems to be somewhat common, but haven't really found any clear fixes.
When I open the drivers side door, the sensor is not detecting it, so the dome lights aren't going on and the radio isn't turning off. The harness seems solid, the latch appears to be fine. It's tough to narrow it down because it sometimes works, sometimes doesn't. Anyone have any experience with this?
This is an '14 JKU btw...
I've got a similar ish issue - TPMS light on. Start car then open and close any door it still says "door" on the dash... all harnesses check out and it seems to only happen when the tpms low light is on. Also a 2014
My understanding is the latch mechanism itself is what senses the status of the door. Assuming the harness is firmly attached and pins are making a good connection, seems the latch might be a bit suspect. Do you notice this happens only with the driver's door, or have you tried to duplicate it opening the passenger door instead? Jahamm's issue seems even more strange.....as though it's more TIPM related somehow. Those 2014 wiring harnesses were a big improvement over previous models too.
ill just wait until my TIPM blows up and then fix it can we discuss the name of that part...what company has the word Totally as a part of the name for a part like this?!
Jahamm - curious, can you recreate that at will if you drop a tire below the threshold? I'd be interested to hear what someone like @ronjenx thinks about your issue. I think every time I see this subject come up it seems much more straightforward like the OP's.
I can't say that I am familiar with what the latch device looks like torn apart, or how it operates, but I'd guess that maybe there is a contact that is dirty or obstructed. I wonder if contact cleaner might be more appropriate if you could find where to spray it. Hopefully someone else will chime in. I try to make mental note of these threads as my jeep gets a bit older........
@resharp001 its one of those things that if you get in, start the car and dont open a door it stays off but once running if you open and close any door it stays on. if you restart the vehicle it goes away. it also causes odd EVIC stuff to happen(only have the basic EVIC, its a sport). missing decimals, ODO not changing mileage until you hit the trip button etc... hasnt really been TOO much of a bother but this thread made me think of it.
Unfortunately, it's not consistent enough to troubleshoot.... Sometimes when I open the door, the Jeep won't detect it (radio off, dome lights on) for 5sec, 20sec, 30sec, and sometimes it will detect it right away. Can't really troubleshoot with such infrequency at this point, so was hoping someone else has had this issue that I can just skip right to the fix.
