Body Lift Raises Side Steps?
I had a quick question...
If i install a 1" BL like daystar's would that raise the side steps as well or would the side steps be the same height?
(Don't have a JK yet
so i don't know if its frame mounted or body mounted)
Thanks!
Thanks!
If the daystar lift works the same way as the MORE body lift then the answer is no. For these lifts you add the spacer and then add longer bolts. Most side steps attach to the frame not the body.
they are mounted to the body so unless the body lift comes with something to keep them the same but you'd want them to follow with the body
if you don't have a jk this is the worst of your worries
if you have a x or sahara with factory steps,they will go up with the body lift because they are attached to the body of the jk.i dont know about rock rails tho because i have a sahara
