2.5" Lift Question/Suggestion
I'm wanting to run 35s so for now I'm thinking of a lower cost 2.5" lift. Eventually I do plan on going with a 4" or larger lift so I don't want to put a ton of money in my first lift, but want a good set up that will really add to my off road fun. So, would you recommend something like the TF BB spacer (with or without shock adapters?) or would a 2.5" coil spring be better? I have a rubicon so what is the best bang for the buck? The difference between the spacer kit and coil spring is only about $100 from TF so that is not much of an issue.
Thanks!
Thanks!
From: Christiana, Tennessee, United States, United States
Thanks!
Thanks!
