Aftermarket brake rotors
Done a little searching....and found a whole lot of nothing.
Are there aftermarket brake rotor kits for the JK? I'd like to put something on better than stock or "Napa" brand. I'm at 30K miles right now and the brakes are just starting to squeak.
BTW, I'll be running 16" Pro Comp 8069 rims in the next couple weeks....so can't go with anything too "big".
Info appreciated
Info appreciated
I had good luck with EBC pads and dimpled/slotted rotors on my old Jeep (great bite and surprisingly long pad life). The JKs have EBC pads available but no "upgraded" rotors. The only aftermarket "upgraded" rotors I've found are from brakeperformance.com[/url]
Hope this helps!
Hope this helps!
I found a brand called frozen rotors that makes slotted rotors. Their web page is just their name. I wouldn't recommend cross drilled for fear of crap getting jammed up in the holes. I've never heard of frozen rotors before but they claim some sort of cryo' process during manufacturing. Just put in your make/model info an it will take you there.
I would suggest staying with stock rotors, Frozenrotors are great, I have put a bunch on "track only"cars, they are very pricey and you wont notice much of a difference on a daily driver, just my .02c.
Appreciate the responses. I checked the "brakeperformance.com" site. They have rotors, but gave no specs..... which is never a good sign.
Guess I'll be looking at stock replacement rotors + better pads. The "big" companies, (ie Baer, Powerslot, SSBC, etc) don't seem to have a replacement rotor for the JK yet.
No, I never said I was unhappy with Napa. I was hoping to find a "true" upgrade, like Baer EradiSpeed (or similiar) rotors, etc. It seems that aftermarket performance upgrade rotors have not made it to the JK line-up yet.
My apologies, I misunderstood what you were looking for. Yeah there isnt too much available along the lines of performance brake parts, I've heard of a couple guys putting some kind of brembo conversion systems or something on their JK's tho.
