Over compressing springs
Can flexing to much with not enough bump stop ultimently damage your springs or what is wrong with not using bumpstops because im thinking about making mine shorter
JK-Forum Founder
having said that, some manufacturers purposefully use taller bumpstops to help prevent rubbing of fenders at a full flex. in those cases, you can make them shorter without any ill effect.
JK-Forum Founder
not necessarily. did you get the extensions that go on top or the ones that get mounted to the axle. i'm not a big fan of the ones that go on top but the ones that bolt up to the axle is what you want. of course, if you have both (as i know the 4" kits come with both), i would ditch the upper one.
You know......I always used to say if I could get my index finger to the knuckle between the coils at full stuff, that was right on the mark. Not very objective......but it always worked for me.
