Help needed!!!
Hi Everyone
I am in need of assistant. I just installed a 4" Rough Country lift and the Dual stabilizers took in for a test run and the steering seem to be very off. And I am getting a traction error. PLEASE HELP! Thanks
you likely need to center your steering wheel. check the write ups for the details.
http://project-jk.com/jeep-jk-write-...-end-alignment
Open the link
Click on the pic in the upper left corner (save it somewhere for quick reference...) The drag link is outlined in a purpley color. And it even says something 'drag link', with an arrow pointing at the, you guessed it, drag link...
Read the "Re-centering Your Steering Wheel " section. Loosen bolts, twist, check steering wheel, twist more, check steering wheel, etc... Tighten bolts. Done
maybe i missed it but where was the sarcasim? you've got some on here trying to help you out.
also, i don't know anything about the kit you bought but hopefully it had something included to address the castor issues with 4" of lift. without it, your jeep will drive funky.
